Cutting an arched frame in wood
I need to cut a circular frame in wood or MDF, however, I do not possess a bandsaw and I am having difficulty finding any wood yards who will cut it for me. I have marked two circles on the wood, one with a radius of 14 inches and another at 16.5 inches (making a 2.5 inch frame), but I cannot accurately cut it using a jigsaw. Has anyone got any suggestions to make my cut more accurate?
Thanks Sibbee
Thanks Sibbee
- Been thanked: 1 time
use a router. cut a peice of 9mm ply about 5 inches wide and about 6 inches longer than half the measurment of the diametre. drill a hole in one end big enough for a guide bush to sit in and drill a 4mm hole the other hend to take a screw as the centre point. put your router with guide bush in the bigger (snug) hole and cut away. do it in about 3 passes.
good luck.
good luck.
- big-all
- Pro Carpenter
- Has thanked: 736 times
- Been thanked: 2341 times
- Gas/Heating Expert
- Been thanked: 9 times
- BANNED
I read an article in one of the woodworking mags the other week about making a circular window. I have it somewhere but not to hand at the mo.
Anyways it was a quite a dull article apart from one top tip. which was to use the fence attachment on your router as a trammel bar, I think that is the right term
Any way set the fence on the router but attach it in reverse so it sticks out from the router. Then drill a hole in the centre of the piece you want a cut out in. The attach the router fence over the drill bit in the hole and rotate the router about this point.
I thought this was clever
- BANNED
Thanks to all who replied. The router idea seems good but I have never used one. Will it cut through 3/4" MDF?
By the way I am a 64 year old woman whose husband is a defeatist, i.e. can't do it, won't try.
The circle I am trying to cut is to be further cut into 4 quarters, which will create the 4 curved corners of a frame I am making for an arched opening in a through room, rather like a door frame on either side of the arch opening.
I know most arched opening are just finished in plasterboard and painted but I like wallpaper and the corners keep getting damaged, hence the idea of a frame to paper up to.
Thanks again for your ideas.
Sibbee
Sibbee
- skiking
- Been thanked: 4 times
Good on ya for attempting this Never let age of sexuality get in the way of thingsSibbee wrote:Thanks to all who replied. The router idea seems good but I have never used one. Will it cut through 3/4" MDF?
I have tackled many diy jobs including fitting a new kitchen and bathroom,
building wardrobes etc. so i'm not a novice. Although I admit that I sometimes need help.
Sibbee
Rather than making a wooden frame for a arch opening why not use this or this
Good luck with it all
