floor Tile cutter
Posted: Wed Apr 08, 2009 2:43 pm
by hooly
will be doing a floor with bnq tiles £10 a metre gray-black type, 10 mill maybe, whats the best cutter i should buy to do the job, for diy use, and how many cuts does a blade last?
any tips as to cutting tiles, and around rads whats the best method?
also fix full tiles, then cut next day, and lay cut tiles? to edge
Do you pva a ply deck first? before adhesive
cheers
Posted: Wed Apr 08, 2009 5:23 pm
by ultimatehandyman
These pages might help-
tile cutting
floor tiling
PVA & tiling
Posted: Wed Apr 08, 2009 6:42 pm
by hooly
ok cheers, £100 say to spend, what tile cutter do you get?
Good guides
Posted: Wed Apr 08, 2009 6:58 pm
by m3 fitter
check the type of tile you have, ceramic or porcelain, and hire a Rubi scribe cutter, and or wet cutter from most good tile shops, or your local hire centre, the cheap tile cutters won't usually be up to the job, with a 9mm thick tile, you may get jagged cuts, or more wastage than neccessary.
Posted: Wed Apr 08, 2009 7:15 pm
by hooly
http://www.toolventure.co.uk/Brands/Rub ... p3065.aspx
ceramic, not bought yet, would the above be ok, was looking at 600 watt electric £100, would rather buy then hire, but if it wont do the job, will have to hire, £100 is top i would pay
cheers
Posted: Wed Apr 08, 2009 7:45 pm
by hooly
Posted: Wed Apr 08, 2009 8:49 pm
by ultimatehandyman
What about this-
dead link removed
and this-
dead link removed
Posted: Thu Apr 09, 2009 6:34 am
by hooly
They look great to me UHM
I just need to know what will ;ast and do the job, Will try to find the tile I'm getting size wise
CHEERS
Posted: Thu Apr 09, 2009 3:27 pm
by ultimatehandyman
The diamond blades in the electric wheel cutters last a long time, or should I say the one that I have has lasted and they are not much for a new one.
Posted: Mon Apr 20, 2009 11:27 am
by hooly
cheers, still deciding, but need to get one this week
http://www.aldi.co.uk/uk/html/offers/2867_5274.htm saw that today in the shop, seems ok
Or is plasplugs from b n q better,? cheers
Posted: Mon Apr 20, 2009 1:38 pm
by hooly
