Can porcelain floor tiles be used on a bathroom wall?
UPM123
Post by UPM123 »
Tiles: White porcelain from Homebase.
Has thanked: 1012 times
Been thanked: 918 times
Post by ultimatehandyman »
Yes, as long as you use a suitable adhesive for porcelain.
fitting porcelain tiles
Man of Kent
Been thanked: 1 time
porc tiles on walls
Post by Man of Kent »
Yes, that is the answer in a nutshell.
I presume the tiles are rather large, and so you may need to be careful re the weight on certain walls. Guidlines suggest 20kgs per sq mt on skimmed plastered walls, 30kgs onto direct plasterboard, 50kgs onto aquaboard etc.
If up tp 30x30cm can use readymade flexible adhesive eg Granfix multifix,Sovereign Gold star. Any bigger, use flexible powdered.
Tiles need sealing with dedicated seal for I presume ,polished porcelain .
Return to “Tiling Forum”
