Silicone over bath
Posted: Fri May 01, 2009 5:08 pm
by EssexBreeze
Hi everybody,
I have a little problem. The gap between the bottom edge of the tile and the top of the bath is 10mm. Any ideas on what I can do to make it look decent? I can do
silicone sealant with masking tape for the edge but, is there anything is available in the market to fit which is better than silicone/ Also should I silicone in 2 layers to get a decent finish (otherwise as the gap is big I find it difficult to get a decent thick edge) I aked this question on the plumbing forum but was suggested to ask on the tiling forum.
Cheers
Posted: Fri May 01, 2009 5:21 pm
by m3 fitter
10mm!!!!!! was that the tiler that you employed!!
howabout jacking the bath up, as the finish of silicone 10mm will not be good
by wine~o
maybe "outside the box" but depending on how far youve got with your bathroom install would it be possible to raise the bath by 10mm?
Posted: Fri May 01, 2009 5:23 pm
by jdpp
I would get some small boarder tiles and run them round the bath or some PVC window frame edging ( the edging is available from Wickes) and can be silicone in place
Posted: Fri May 01, 2009 5:56 pm
by EssexBreeze
Thanks for the replies.
Yep, its the tiler I employed. Wasnt that good.
The bath is a free standing bath. So there is no way I can jack it up.
Anybody know much about the teleseal or whatever they have recomended in this website?
Cheers
Posted: Fri May 01, 2009 7:49 pm
by ultimatehandyman
The teleseal is supposed to be good, but there are alternatives.
As already mentioned you could use quadrant tiles
Or I am sure there is another seling strip available for around baths.
Posted: Sat May 02, 2009 3:43 am
by m3 fitter
If the bath is freestanding? why not add an extra course below the original..by un plumbing the bath..and moving it while you tile, be a shame to spoil it with a dodgey seal
Posted: Sat May 02, 2009 6:49 am
by thescruff
Now that's what I call Lateral thinking m3 fitter
Posted: Sun May 10, 2009 3:59 pm
by EssexBreeze
Thanks guys for all the advice.
Cutting all the adhesive and replumbing will be too much of a job now especially as the flooring has been done.
I have decided to try a piece of window beading and see how that looks.
Cheers
Posted: Sun May 10, 2009 9:32 pm
by Only-Me
Posted: Sun May 10, 2009 11:14 pm
by EssexBreeze
It was suggested trying the PVC window frame edging and being cheaper and easier to find I decided to use it and see.
Posted: Mon May 11, 2009 8:14 am
by pistonbroke
Whats that saying about ships and a half pennies worth of tar?
Hope it looks good when you have finished, remember its only a bodge if it looks like a bodge when you have finished!!
