Toilet under tiles
hooly
Has thanked: 1 time
Been thanked: 2 times
Toilet under tiles
Post by hooly »
I want to take the toilet up, and tile under, Plumbing know how = zero
CIMG0622 (Small).JPG (36.96 KiB) Viewed 1993 times
hooly
Has thanked: 1 time
Post by hooly »
Can i get a flexible bit, as the toilet will lift quite a bit higher?
thescruff
Has thanked: 360 times
Been thanked: 3735 times
Post by thescruff »
You should be able to use what you already.
Note the extension piece isn't fully inserted, it looks as though its pulled out.
m3 fitter
Tiling Expert
Has thanked: 7 times
Been thanked: 14 times
Post by m3 fitter »
if not use a jollyflex pan connector from the original svp and then connect your existing 90 to the end, to be safe, available from most diy stores and here:
http://www.toolstation.com/shop/Plumbin ... 887/p65378
hooly
Has thanked: 1 time
Post by hooly »
thescruff wrote:You should be able to use what you already.
Just checked, its in tight, wont go no more, at the limit
cheers both
thescruff
Post by thescruff »
There's nearly three fins sticking out which shouldn't be, try twisting and pushing at the same time.
How much are you looking to raise the pan.
If you go for the jollyflex pan connector ( I would use whats there) get the bent type so you only need one fitting.
hooly
Has thanked: 1 time
Post by hooly »
12 mill ply, 8 mill tile, and the say 5 mill of adhesive..approx
will try when i go back upstairs :lol:
thescruff
Post by thescruff »
Are you keeping the existing suite, the outlet height varies quite a bit.
Looking at the pic, so it's not clear, but I would go for a plastic socket on the existing pipe with a short length of pipe and a 112% bend into a bent pan connector, that would give you around 25-30mm
hooly
Has thanked: 1 time
Post by hooly »
I think the right side pipe is too far in the middle bit, hense that not fitting right, cheers
I have a idea what i now need when its raised
Return to “Tiling Forum”
