Serious grout problem!
- Has thanked: 1 time
A few months ago my kitchen floor was retiled by a professional tiler. The original floor is concrete. Over this he laid a plywood base to fix the tiles on. My problem is that the (flexible) grout he used just won't stay fixed. I have had to re-grout on numerous occasions since he left.
The grout quickly begins to crumble and in no time at all, it comes out in large chunks.
Is there anything I can do or use that will make it last as it should?
- wine~o
- Has thanked: 1414 times
- Been thanked: 4019 times
- thescruff
- Has thanked: 360 times
- Been thanked: 3735 times
- Tryanything
- Been thanked: 4 times
- Tiling Expert
- Has thanked: 7 times
- Been thanked: 14 times
sounds like the screed was a floating floor, which is meant to always have movement, some inexperienced tilers don't recognise that floating floors cannot be tiled without uncoupling them with ditra mat, which is a uncoupling membrane, the adhesive and grout also have to be flexible, but in the main floating floors have always been a hit and miss operation and are to be avoided as regard to tiling, ask the original builder if the floor is floating, if it isn't, then the movement is being caused by the plywood not being screwed down properley, and the answer will be a strip, and re-tile
