Slugster wrote:Hi Richie,
Thanks for that. I'm going to drill through from outside into the floor void (between Ground and 1st) and pull their cable into that. It currently comes in by the bottom of the front door.
Have you got a photo of where the cable comes in now that shows where it needs to go to? To be honest, I would leave the cable coming in on the ground floor and just extend it from where it is now having the least amount of outdoor exposed cable as possible.
I have a question on this too....
Where the cable comes in now, is the floor solid concrete or wooden floorboards? If its wooden floorboards then I think its best to run the cable under the floorboards to your "understairs arrangement" as this not only minimise's the exposure to the cable but keeps it protected inside the house and allows easier access to it if ever need be.
You would want to keep in mind that if your telephone cable comes in between floor levels from the outside it can look unsightly when selling your house and costly should a BT engineer want to get access to it later.
Slugster wrote:I'll probably have to extend it to reach the cupboard but it'll be worth it.
Got a picture of where it is now and where it needs to reach to?
Slugster wrote:
I've gone back to Cat5E. Can't be bothered paying CAT6 money and I won't be running a gig in the house anyway.
CAT6 is better insulted though, depending on the cable you buy and where your planning on running the cables too. Keep it well away from power cables and light fittings.
In fact, why dont you just go wireless?
Also, if your going to do the job anyway, why not add value to your house by future proofing it so that when you come to sell it, the few extra quid for cable adds hundreds to the value?
You can get rolls of CAT6 on ebay nice and cheap...
Slugster wrote:
Even if technology move to HD streaming over UTP I'm fairly sure 100mbps will do. And if it doesn't I'll have moved by then anyway..!
100Mbits is fine
Wireless will soon outpace 10/100 anyway but keep in mind the resell value of your home. Its like having a dated kitchen....
Slugster wrote:
I've got single pair DSL so I'm just going to put a micro filter into the understairs DP, take the DSL into the modem and hub. Then from the hub to the patch and fan out to the rooms from under the stairs.
What a lot of work... Wireless (Secured properly is much easier)
Slugster wrote:
Not sure what to do about phones. The most we'll need is 3 so I was thinking about splitting out from the one microfilter (with a bit of hooky cabling) but I've heard this can lead to hiss and crackle.
Have you any experience with this?
Dont use hooky cabling, it will only bust on you later or give you more problems than you started with.
Go get yourself 1 Telephone master socket and 2 or 3 secondary sockets.
(Make sure its the sockets with the 2 screwdown connections, NOT 6 punchdown sockets)
You can then have 3 or 4 telephone sockets under your stairs and use 1 ADSL filter in each socket then plug in whats called a triplex adapter into the filter, then an RJ45 cable into the triplex and patch this into your LAN.
Then wherever you want the phone in the house, just plug in a PSTN master adaptor and plugin your phone into that!
I'll dig you out a photo / diagram of how it fits together if you like?
In fact, might go one better as I'm about to do the same over the next few weeks so by the middle of April I should have everything in place so might just write up a tutorial for you if ya like?
I'm planning on having my routing kit under my stairs and 4 telephone sockets (The max) so I can have both office phones in the office and cordless phones in case the wife wants to take a call in the garden.
Slugster wrote:
As for history, it's been about 7 years since I pulled any cables or fibre, now it's just organising to get it done
If pulling cables really isnt your thing, then why not try these new mains adaptors that use your electrical wiring as lan circuits? There totally weird because typically, Data and power cables are like electric and water..., yet this just looks like a battery charger but with an RJ45 socket on the bottom of it.
Not my thing really but some people like them and say they work really well.
I'll catch up with you later maybe then...
Richie
I'm new here.... go easy on me!
