hi everybody,
I have just finished laying some marble tiles on my cloakrrom floor. I have bought a Residue remover and a sealer from Topps tiles to seal it. Once i have smeared the residue remover do I use some sort of a scrubbing pad on a grinder to clean it and do i again use some polishing pad once the sealer is in situ?
Basically can someone tell me how to use these damn things.
Cheers
Sealing marble
- EssexBreeze
- EssexBreeze
Thanks a lot.
It does not say if tis adhesive or not on the tin. Its made by a company called Fila.
Can I use polishing chamois pads attached to a grinder to polish it off at the end. In my other bathroom there seems to be some paint mark sort of marks on the tiles when you shine a light on it. Is that because it was not polished properly? Can I apply another coat of the filler and polish it now?
Cheers
Cheers
- Tiling Expert
- Has thanked: 7 times
- Been thanked: 14 times
use the fila fob sealer to reactivate the old sealer and buff with a machine if required, remember you won't get into the corners with a circular buffer, for a uniform look, the paint type marks are probably grout residue as you would have used flexible grout with additive, a new coat of sealer rubbed vigorously should remove it.
- EssexBreeze
