split load CU
devlin
split load CU
Post by devlin »
Hi Again
Are split load cu,s varialble IE can I have the split on say the ring in the kitchen only with 30mA rcd as this is the ring that I would use any outdoor tools on
Devlin :?
sparkydude
Has thanked: 2 times
Been thanked: 149 times
Post by sparkydude »
A lot of mnafacturers sell them in a certain configuraion IE 6+6 or 6+4 but if you buy an MK one then you can just buy the enclosure,main switch,RCD and a split load kit to configure it any way you want. If it is only the one circuit you want RCD protection on why dont you just use a single module RCBO which is an rcd and mcb combined in one unit, that way you can just put it on the circuit you need in a main switched board, no need for a split load board.
Nick
devlin
Post by devlin »
Thanks Nick
I knew there would be a way to do this its just I don,t have a lot of practical experience on using the products availabe for general / domestic installs being limited to defined applications with some variation
Thanks again
Devlin
Return to “Electric Forum UK”
