Raising floor: chipboard or ply to take porcelain tiles?
Posted: Mon Jun 01, 2009 9:10 pm
I have a utility room that currently is tiled on the floor. I need to raise the floor level by about 40mm and then will tile with porcelain tiles. The area is approx 2 x 1 metres.
Should I use layer(s) of flooring grade chipboard or ply, or a layer of chipboard and then ply?
Do I need to fix the flooring through the existing tiles (concrete floor underneath) or can it float?
I assume that as it is a utility room I should use water resistant materials?
Any recommendations on tile adhesive to use?
Thanks,
Gerry
Thanks,
Gerry
