how to get grout off the tiles
siraz
Has thanked: 34 times
Been thanked: 1 time
Post by siraz »
My wife been cleaning the tiles and soon it is dried, the cloudy effect appears on the tiles and she has had enough of cleaning the tiles for the past 3-4 days.
What is the beat way to remove this stuff quickly or is there something on the market which you can buy.
She has been using clean water and sponge. I left the gorunt for few days due to hot weather kids wanted to go to the theme park.
leebwk
Has thanked: 3 times
Been thanked: 31 times
Post by leebwk »
If you have cleaned it a few times water a wet cloth/sponge then wait until dry and then clean off the cloudy residue with a dry cloth or a dry sponge using a damp cloth will just spread it about
siraz
Post by siraz »
Thanks Leebwk, i will give it try this evening or by the cleaning agent the grout remover from the tile shop.
AAJ Tiling
Post by AAJ Tiling »
what tiles are they ceramic, porcelain???
imagine there the latter some porcelain needs to be sealed proir to grouting as the like to soak everything in.
if this is the case, carry on with the advice already given with plenty of elbow grease try also working samller areas i.e a m2.
your local shop could supply a cement grout remover. beware they can be acidic try on a small area as the can damage your tile and grout
http://www.aajtiling.co.uk
siraz
Post by siraz »
Thank you for your reply,
I have managed to remove it, but my grout line they are not vertical or horizontal in straight line, as there are some excess grout build up during the application of the Grouting.
I used the HG Cement Grout film Remover
My Tiles are Ceramics from B&Q.
HG cement Grout film Remover.JPG (27.71 KiB) Viewed 2953 times
siraz
Tiling pictures and ensuite
Post by siraz »
I am attaching pictures of the tiling which i have done and fitted the Toilet, Towel rad, Basin.
Electric shower not connected yet, Architrave not fitted yet and the Shower Bi fold Door. It will be done at the Weekend.
There are grout line which has been over filled and over flow, as they look like a wide grout line.
siraz
Post by siraz »
see further picture
thescruff
Has thanked: 360 times
Been thanked: 3735 times
Post by thescruff »
I love your pics Siraz, I can spend hours working out which was is up. :thumbright:
Has thanked: 1012 times
Been thanked: 918 times
Post by ultimatehandyman »
I like your pictures too as you are one of the few people that attach the pictures, rather than hosting them on other sites :thumbright:
Return to “Tiling Forum”
