Mains plug socket on/off switch jammed
Locked
impulce
Post by impulce »
Hi i wonder if anybody can help,
I was using the microwave today when it stopped and then started flashing on and off as if it were getting intermittent electricity. I immediately tried to turn it off at the wall and the switch will not turn off, so i just pulled the plug out. The microwave works in other plug sockets and is fine, as is the plug socket next to the one that is jammed (its a double socket). The switch will just not move.
Ive never come across this before and wondered if anybody had any idea what it would be.
Thanks!
EJJ150847
Has thanked: 35 times
Been thanked: 188 times
Post by EJJ150847 »
Probably overheated and will need replacing.
Could be loose cable inside, worn out over time, overloaded at some time this list is endless.
John
Sparky James
Has thanked: 8 times
Been thanked: 76 times
Post by Sparky James »
Replace the socket the switch contact has overheated and melted the spring plunger thingy.
Buy a good one MK or Crabtree are the best in on particular order.
PS dont forget to turn off the power.
:wink:
3LanceMechSparky
Re: Mains plug socket on/off switch jammed
Post by 3LanceMechSparky »
impulce wrote:Hi i wonder if anybody can help,
Thanks!
Socket Outlets don't last forever... Turn the mains off and change.
Locked
Return to “Electric Forum UK”
