Back door kicked in!
Posted: Mon Mar 12, 2007 5:08 pm
by Handy Angie
You will never believe what happened to my back door this weekend - it got kicked in! Its only a cheap door and I want it to be safe in the future so would you recommend fixing it or buying a new one?
Posted: Mon Mar 12, 2007 5:18 pm
by ultimatehandyman
Erm, I'm not sure about this one
Posted: Mon Mar 12, 2007 5:21 pm
by Handy Angie
Errrrr it wasnt a trick question! There is a panel that seems to be made from plywood which was the bit that was kicked in - so I may just hammer another piece over it for now until someone gives me a better answer. Id send you a picture but its raining where I live.
Posted: Mon Mar 12, 2007 5:24 pm
by ultimatehandyman
I'd screw your back door rather than nailing it as it is much better.
Posted: Mon Mar 12, 2007 5:45 pm
by skiking
I got burgled about 10 yrs ago. The tossers kicked thru' the thin panel and climbed thru'. Three hours after returning home I was robbed again, this time by the chippy who charged me £100 to put up another piece of plywood in place of it. :evil:
I ended up buying a new door
Posted: Mon Mar 12, 2007 6:45 pm
by dewaltdisney
Avoiding the double entendres about firming up your back door it will be neceesary to have a good look at the damage. If the door frame and locks have held well then you can make a decision on the door itself. Ply panels are not really strong enough unless they are thick and well fixed.
I would replace the panel with two pieces of ply. One to fill the panel rebates to come flush with the surface of the door and then another one overlaping with enough overlap to scew though to the door face. Glue it in teh channels and together with a strong adhesive, something like Evostick Strong Stuff. Chamfer the edges and paint to suit.
Should be strong enough to stop this happening again but take time to look at your security generally.
Posted: Mon Mar 12, 2007 7:29 pm
by Handy Angie
Yeah same as me - the freak climbed in through my back door too. Hope to god it wasnt the same guy. Mine left a big footprint on the kitchen lino having measured it it was a size 8! Believe me when I find the owner of the footprint he will need to be able to run fast cos when I catch him he will never escape my clutches! Ive only got a hand saw so its going to take me all night to cut through the plywood - it always happens when Corrie is on. But I wont let the buggera win!!
Posted: Mon Mar 12, 2007 11:54 pm
by dirtydeeds
here are the facts
98 percent of all burglers go for the back of the building and most go through the back door
WHY? because most houses in this country have cheap back doors fitted with two lever locks which are out of sight from the main road
ive fitted a strong back with a 5 lever mortice lock. consider this when you spend your hard earned money
Posted: Tue Mar 13, 2007 9:18 am
by dewaltdisney
Get it cut to size at BnQ
