Fitting Skirting Board: It is a job for a pro?
Choggy
Been thanked: 1 time
Post by Choggy »
I need to fit new skirting to a couple of walls (one of which has a bay window). I've never done any carpentry (tho I'm a very practical person and am certainly interested to learn), but I haven't the first idea where to start.
Is it a difficult job? If so, perhaps I should just call in a pro (despite the fact that I'd really like to learn how to do it myself and am keen to save a bit of dosh if I can do a job myself)? If it's something that a beginner can do, does anyone know of How To article (I've googled, but can't see anything)?
Thanks in advance
skiking
Been thanked: 4 times
Post by skiking »
Try this link for starters
If your still not sure just ask specific questions and you'll get the advice you need
Choggy
Post by Choggy »
Thanks Skiking, that certainly has given me a basic grounding in putting up the skirting.
There's going to be two external angles and neither of them will be 45 degrees because they are at the corner of a bay. I have no idea how to use a mitre or how to work out what angle the joint will need to be. Can you help?
Two of the internal joints (again, in they bay) aren't 45 degrees either... how do I get them right?
Has thanked: 1012 times
Been thanked: 918 times
Post by ultimatehandyman »
Hi Choggy,
for angles that are not 90 degrees you ned an angle finder like this-
http://www.tooled-up.com/Product.asp?PI ... --Anglefix
Then you take the measurements and transfer them directly to the mitre saw-
owen
Post by owen »
choggy, if you are painting the skirting then it is definitely worth having a go yourself, as filler can hide a lot of bad joints :grin:
if however you want to leave the wood natural/stain it, then you may find it a lot harder to get acceptable joints so it may be worth getting a chippy in
panlid
Post by panlid »
i hate doing skirtings. only marginally more than fitting doors.
all that kneeling and then standing and dealing with crumbly plaster in old houses.
::b
tim'll fix it
Post by tim'll fix it »
panlid wrote:i hate doing skirtings. only marginally more than fitting doors.
::b
anything you do like fitting :wink:
panlid
Post by panlid »
im thinking :? :lol:
Scrit
Pro Cabinetmaker
Post by Scrit »
Could be worse, panlid, youy could have to repair those wonderful plaster skirtings found in some Victorian houses......
Scrit
Measure twice, cut once - except fingers!
panlid
Post by panlid »
i could but i wouldnt turn up :wink: :lol:
i like fitting stairs, knocking walls down, framing walls but above all else i love filling skips :thumbright:
wood4fun
Has thanked: 2 times
Post by wood4fun »
i love filling skip :thumbright:
panlid
Post by panlid »
good work out :thumbright:
Choggy
Post by Choggy »
ultimatehandyman wrote:Hi Choggy,
Blimey, is there ever an end to the number of tools you need to get a job done?! Mechano and lego were a whole lot easier than this... it's a shame you can't build a house outta 'em :-/
Can Mitre saws be hired?
You can hire an electrically powered one, which will make it easier or you can buy a hand powered mitre saw for about £20
panlid
Post by panlid »
if you are planning to do your own skirts i would say you are into a bit of diy. surely buying an electric one for 20 quid makes sense in the long run?
