kitchen worktop
Locked
ronny47
kitchen worktop
Post by ronny47 »
hi all
what is the best saw to use for cutting sink out of worktop ant tips will be really grateful as am a novice. thanks : :hello2:
stephenf8542
Post by stephenf8542 »
A good jigsaw with a sharp blade.If you can get a laminate blade all the better to save chipped edges
Has thanked: 736 times
Been thanked: 2341 times
drill 2 x8mm holes in diagonaly opposit corners 2mm overlapping the cut line use 101b or d blade
if the blade starts to wander or it gets harder to cut change the blade
be wary off the carcas underneath
you must fully support the weight off the cutout when your down to the last edge if the worktop is in situ but loose you can use a bit off 3mm hardboard mdf or ply 650 x 90% the length just make shure it goes under the front and back rails
you can also just support it by hand
and last off all dont lift the worktop with a cutout without asking how!!
lockie
Has thanked: 32 times
Been thanked: 122 times
Post by lockie »
Ive done it a different way to this with good results.Mark it all up using masking tape then use a circular saw/trim saw to plunge in and run it along the straights stopping before the corners.Use a jigsaw to cut the last corner bits out but support the offcut. Found this an easier way of getting nice straight lines as i dont have a really good jigsaw.
Inky Pete
Has thanked: 12 times
Been thanked: 161 times
Post by Inky Pete »
I've always done it the same way as lockie.
ronny47
kitchen worktop
Post by ronny47 »
lockie
hi lockie
thanks for the advice
ronny47
kitchen worktop
Post by ronny47 »
stephenf8542
hi stephen thanks for the tip
ronny47
kitchen worktop
Post by ronny47 »
hi big-all
thanks for the advice appreciate it
Locked
Return to “Kitchen Fitting”
