Kitchen floor tile height and flooring choice
lagi
Has thanked: 141 times
Been thanked: 53 times
Post by lagi »
Can somebody give me a rough height that adding kitchen floor tiles (the most common size) and adhesive adds to a floor?
Also i am laying a new floor to stick these on. T/G m/r chipboard or wbp ply, the first being preference as easier for me to collect and any left over i can use elsewhere. Any problems with using this???
Has thanked: 1012 times
Been thanked: 918 times
Post by ultimatehandyman »
It depends what tiles you are using. Some natural stone tiles are much thicker than porcelain tiles.
If there is already a wooden floor down you can rip it up and replace it with 25mm WBP if you are concerned about the height of the new floor.
lagi
Post by lagi »
There are floorboards down which i shall be removing but i can only put back down 18mm. As i don't have the height at the end of the room. So its either ply or t/g chipboard.
I thought the chipboard will be easiest to lay down on the joists.
Only-Me
Been thanked: 3 times
Post by Only-Me »
Ply is better........more stable.
Assuming your talking of your average tile..........which can be around 8mm-10mm. Then cement.....6mm-8mm
:thumbright:
Return to “Tiling Forum”
