Preparation for tiling
I have recently had my kitchen re-wired and a new kitchen fitted. Last thing to do is get some tiling done. I have attached some photos of the walls i a looking to tile and would like to know what you guys think the best prep work i can do to give a good finish? They are a quite uneven at present.
ANy advice gratefully received!
Cheers
Jock
Cheers
Jock
- small wall
- photo1.jpg (120.56 KiB) Viewed 1549 times
- big wall
- photo3.jpg (100.41 KiB) Viewed 1549 times
- big wall
- photo2.jpg (94.93 KiB) Viewed 1549 times
- Mr. Grumpy
- Has thanked: 25 times
- Been thanked: 109 times
Jock, I plastered a similar area and it is not easy by any means for a DIYer, especially at the edges as you rubbing the trowel off the walls etc. I found it impossible to get it flat and it looks sh#t when tiling. Spend ages sanding it down. There was a lot of this
The lads can advise you but I wonder if you can use plasterboard or 6mm hardibacker or aquapanel. You would see the thickness as its cover by the units. I have no clue if you can use 6mm on walls
Wait for the lads as I am in no position to give advice
The 'toaster ' wall will be fine, just fill in the chases with bonding plaster (pop some metal capping over the cables first) give the painted sections a quick score with a stanley knife and it's ready to tile.
With the 'hob' wall I would suggest taking off the sockets and any other switches, terminate the cables with connector blocks and insulation tape and then skim up. You could always remove the plasterboard and space it off to get it perfect with the existing p.board. Whatever happens, the plasterboard seriosuly needs more screws in there.
