http://www.argos.co.uk/static/Product/p ... 231167.htm
As soon as the first generation of this type of machine came out, I thought it was an obvious idea. But after reading the reviews, they all didnt like it, mainly due to the water being warm, not boiling (hence, now £25 new on ebay)
This new one is great, and all the problems have been fixed. Had it a week now, and its used every day.
So, how long till its payed off? You have to take it that you always boil more water that you need for 1 cup in a normal kettle, and its apparantly much more efficient at boiling the water. Based on having 6 cups a day
tefal quick cup deluxe
- thescruff
- Has thanked: 360 times
- Been thanked: 3735 times
- big-all
- Pro Carpenter
- Has thanked: 734 times
- Been thanked: 2335 times
2 cups = 1l ish
2.5kw kettle boils 1L in 85 seconds so
1L= 1/43 off 2.5 units about 1/2p at 8p a unit
now if the tefal can produce a cup for 1/4 p thats 400 cups to save £1
at 8 cups a day thats around £7 a year saved or around half the amount you can save if you boil your cupfull in the microwave
any way assuming it costs £35 thats 5 years pay back
ok just seen your 6 cups a day so thats nearer 6.5 years pay back
and if its £86 thats around 16 years
- Has thanked: 6 times
- Been thanked: 11 times
just seen this in one of the argos reviews
"We plugged our item into a meter that records the Kwh usage & it showed that for 2 mugs it used 0.04Kwh. I poured the same amount of water into our normal fast boil kettle & it used 0.07Kwh. So nearly twice as much energy used. "
and thats not taking into account that you would boil more water than exacly 2 cups in the kettle. On these figures, whats the saving? (dont know how to work it out)
- big-all
- Pro Carpenter
