Have a go myself ??
Posted: Wed Nov 04, 2009 4:52 pm
by Pristineplastering
Evening all,
As you can see from my log on, I'm a plasterer by trade and so able to do any prep work prior to tiling.
I want to update my bathroom (very small, 6' x 4') and thought I'd have a go tiling it myself
Can anyone just give me a quick list of 'must have' tools to do the job to a resonable standard
I've never ever tiled anything before and apppreciate I may well come across a few issues but I'm trying to do things on a budget, hence my post here
Should it prove too much, can you advise how long it might take a professional tiler to complete ?
Many thx
Posted: Wed Nov 04, 2009 5:55 pm
by Stella
What type of tiles will you be using?
Ceramic or natural?
Will any holes need drilling?
Posted: Wed Nov 04, 2009 7:29 pm
by ultimatehandyman
You'll need a tile cutter, which one depends on what tiles you are using.
If you are using smooth ceramic or porcelain you need a tile cutter
But if you are using natural stone tiles you need a diamond wheel cutter-
like this
A tile file is also handy for removing any sharp bits-
tile file
You will also need a notched trowel, although you probably already have one of those!
Tile spacers will also be required.
If you need to drill any of the tiles, this might help- tile drilling
If there is anything you are not sure about just ask :wink:
Posted: Wed Nov 04, 2009 8:02 pm
Thanks guys, much appreciated - think I'll be using ceramic / porcelain tiles - the natural ones sound pretty expensive, especially for a novice cos I'm bound to break a few
Posted: Wed Nov 04, 2009 9:16 pm
by DIY_Johnny
I assume you also need a group float, grout sponge also. Also for the silicone, these are superb. Bad silicone looks awful. Bit pricey though
Being a plaster, I think you no problem at all as you will certainly will have a lot more skill than a general DIY novice like me.
I tiled my kitchen and bathroom recently and some things I learnt were (the pros have probably forgotten what its like to be a novice :lol:)
1. It best to get a electric tile cutter if you need it, they are cheap anyway and will do a better job. I spent a lot of wasted time, fannying about on tile cutting with jigsaw tile blades, using tile nips etc. Waste of time and broke more tiles than the cost of a cheap electric cutter. You will regret it afterwards. I only bought it at the end of the job when I just could cut a corner out of a floor tile no matter what I tried
You also can cut squares in the tiles if need be (e.g. kitchen socket), miter external corners etc
2. Avoid the really cheap rail type cutters, I bought one on screwfix, was £12 or something, total sh#t, couldn't cut a straight line for anything.
3. Metal trims look great but costly :sad:
4. Don't assume tiles are all the same size. Mine weren't!
5. Don't assume the walls are straight or parallel but you're the plaster so you will know a far better than me on how to check/fix! :lol: One of my walls appeared flat but bowed in like a banana, so I started tiling at the corner and ended up with an increasing grout line. Now I wonder who did that plastering :oops:
6. I never had a problem drilling into tiles with a masonry drill on slow speed and taking it softly but maybe I was just lucky!
7. I avoided the rapiset adhesive cos I work sloooow.
8. Blockwork pattern looks great in my opinion but plan it out as you can end up with slivers at the end. Again i could have done one wall better.
9. Making holes for pipes, rather than cutting a piece out looks good but depends how anal you are.
10. Clean off any excess silicone before it dries, I had a nightmare of a time getting it off the metal shower edges
Posted: Wed Nov 04, 2009 9:24 pm
by tictic
check out tradetiler.co mate u will be able to see the tools u will need and also the prices.
preperation is the key mate..i.e. substrates plat,layout of tiles try not 2 have rakes/slivvers in ur corners...and just take ur time.
best of and has already been said ask away for any advice :wink:
Posted: Thu Nov 05, 2009 8:54 pm
by lamntile
If you go into a Topps Tiles shop they usually have all the tools on display behind the counter
