Tiling over Ply on stud walls
Denzil
Post by Denzil »
Hi to everyone,
I am in the process of 'creating' a bathroom/shower upstairs and was about to line the stud walling around shower area with 12mm WBP ply as a base covering. I have spent the last goodness knows how long reading the various opinions relating to this general topic! :scratch:
Can someone enlighten me? Should I carry on and tank that particular area..burn the ply and use aquapanel..leave the bathroom downstairs?
HELP ::b
Unfortunately this is likely to be the first of many such pleas!
Thank you
DIY_Johnny
Mr. Grumpy
Has thanked: 25 times
Been thanked: 109 times
Post by DIY_Johnny »
The tilers will be along soon but using Aquapanel is an easy job Denzil.
Its strong heavy stuff. I used 12mm aquapanel and tanked it, fairly straightforward job but I think that was overkill, but you buy a tanking kit so all the bits and bobs come in the one kit, simply to install. and when its done its there for life
But I guess now that you have bought the plywood, you may want to use it. You might just wanna check with the guys that you have the studs in the right centers as 12mm ply can be flexible me thinks :wink:
Don't forget you undertile bath/shower sealer thingy. They are in all the stores, usually called Homelux
lamntile
Contact:
Post by lamntile »
Do the walls with aquapanel then you have the perfect base for your tiles , also if your tilling the floor again us aquapanel screwing it down onto the joists.
If you are tilling the floor check with the mfr of the shower tray as to what it should be placed on.
Paul
tictic
Has thanked: 5 times
Been thanked: 23 times
Post by tictic »
with lamtile on this 12mm aquapanel..wouldnt advise any wbp ply on walls "at all" in wetroom/bathroom. :wink:
DIY_Johnny
Mr. Grumpy
As a matter of interest, whats your thoughts lamintile/tictic on D'n'D aquapanel or fixing to wall.
I think building a frame around to support the aquapanel is a real draw back as it makes the room smaller. A lot of bathrooms as so small that it becomes an issue :wink:
Denzil
Post by Denzil »
Thanks for that, I will have to build something else with the ply!
Since my post I have removed a section of flooring to install a shower deck. Once installed it will be at the same level as the existing t&g flooring. Can I lay homelux or similar and tile or do I have to muck the levels up by laying additional ply?
Nothing is ever simple.....apart from a DIYer with a chainsaw that is!
tictic
Post by tictic »
NewbieJohn wrote:As a matter of interest, whats your thoughts lamintile/tictic on D'n'D aquapanel or fixing to wall.
ALWAYS mechincal fixing for aquapanels newbiejohn never dot/dab them u will not have any manufacturers guarantee mate :wink:
tictic
Post by tictic »
Denzil wrote:Thanks for that, I will have to build something else with the ply!
lay 6mm backerboards glued and screwed then tank over it with homelux floor matting. :wink:
tictic
Post by tictic »
sorry denzil also prime the floor fisrt with either bal apd or sbr proir to 6mm b/boards.
tictic
Post by tictic »
also john most b/room are already p/boarded and studded so its just a case of ripping p/b off and reboarding onto exsisting stud work..
or if brick, plastrered walls etc.. stud out, i use 80mm fischers usually onto 2x2. :wink:
tictic
Post by tictic »
overboard with 6mm b/b.. :shock: need 2 reread my own posts ere... :lol:
tictic
Post by tictic »
just in case "someone"jumps down my throat.. :lol: only kidding..how u doing the scruff mate..hows that driveway coming on bud :thumbright:
DIY_Johnny
Mr. Grumpy
Regarding aqua panel. For my bathroom I had a real issue with space. Shower tray was just too wide to build a frame. I had solid walls so I d’n’d aquapanel mainly to just get it level (every though the manufactorer said not too!) I swung out of it like a retarded ape. It did stick hard, however given that its supposed to be mechanically fixed I put 60mm fisher fixings in at 300 centers. Tanked (shower area only) it over and tiled Went ok.
I suppose the better way to do it would be to just plaster or render the wall and then tanked but my plastering looks like it belongs in the Tate modern :lol:
For my learning what do you think about that way (feel free to be critical!)
tictic
Post by tictic »
NewbieJohn wrote:Regarding aqua panel. For my bathroom I had a real issue with space. Shower tray was just too wide to build a frame. I had solid walls so I d’n’d aquapanel mainly to just get it level (every though the manufactorer said not too!) I swung out of it like a retarded ape. It did stick hard, however given that its supposed to be mechanically fixed I put 60mm fisher fixings in at 300 centers. Tanked (shower area only) it over and tiled Went ok.
should be ok john :wink:
but maybe next time d/dab 12.5mm moisture resistant p/board then tank or brush up on ur plastering skills :lol:
DIY_Johnny
Mr. Grumpy
Cheers tic tic
Plastering really puts me in a bad mood, any time I do it there is a lot of this :cussing:
Return to “Tiling Forum”
