Bad grout or bad technique?
- Has thanked: 28 times
- Been thanked: 71 times
Been tiling lately and have noticed that as the grout dries it forms a crease down the length of the join - as if the grout has shrunk a little leaving a line.
I've used Wickes all purpose waterproof adhesive / grout.
Is this because of rubbish grout or rubbish technique?
- wine~o
- Has thanked: 1414 times
- Been thanked: 4019 times
I had the same problem with a different brand, Can't remember which, but found that using a rubber float (bit like a squeegee, only thicker) solved the problem. No idea why this worked though.
I did wonder about the adhesive / grout.tictic wrote:honest mate..its not the best of stuff you have used,"the all in one."
i dont think it will be ur tech...
i would only ever use a good branded bagged grout,bal,mapie,etc..
9/10 water damage is usually done to grout failure.
Used it as it is just so handy not having to mix up from bags.
Might give the Bal stuff a go as I was really impressed with their primer.
- Razor
- Has thanked: 483 times
- Been thanked: 1251 times
Never ever use adhesive and grout all in one, doesn't stick, doesn't grout and leaves grainy white stains all over the tiles.
Only time it's suitable is when you're doing maintenance and have to cut out and replace one or two tiles.
Horrible horrible stuff and expensive!
If a customer supplies it I always refuse to use it or just refuse the job.
Ps I really don't like it
- Mozzy Jones
- Been thanked: 1 time
