Help! Water leaks through grout.
Dear All,
We had our bathroom tiled recently. Yesterday I found that water is leaking through the grout between a few tiles close to the bath. Can anyone here tell me if I can remove the grout and use sealant between these few tiles? Also what is the best way to remove grouts? Thank you.
Regards,
Summer
Regards,
Summer
- Has thanked: 28 times
- Been thanked: 71 times
You say you 'had' the bathroom tiled - does this mean you paid someone to do it?
If so drag the toe-rag back round and get them to put it right.
If you do it yourself then use the grout rake (link in chris_h's post) and use a good waterproof grout - sealant will look odd and more than likely discolour / go mouldy in time. Make sure you leave the grout a good 24 hours to dry before getting wet.
Bit odd that a little missing grout is letting is water - whats behind the tiles? Should have a solid bed of adhesive behind the tiles?
