uncalibrated slate linear mosaic bathroom tiles
Tim Robo
Post by Tim Robo »
thanks for checking the thread, I have purchased the above tiles for the bathroom and as they "butt" together and do not, in theory require grouting, however, there are slight gaps between some of the tiles. Does anyone know the best way of sealing them without grout.
many thanks
tictic
Has thanked: 5 times
Been thanked: 23 times
Post by tictic »
what thickness do they range from?
what sizes do they range from?
what substrate are you fixing to? :scratch:
Simon Site Manager
Has thanked: 48 times
Been thanked: 202 times
Post by Simon Site Manager »
Hi Tim,
Have not heard of these tiles before, would love to see a picture.
Thanks,
Simon
Tim Robo
Post by Tim Robo »
Hi tictic / Simon
the tiles come in normal tile size "mats" like mosaic tiles, they are irregular with varying thickness, but only mm diff. the tiles come from Topps but have not seen them on their site. will post a photo asap. they are put on with waterproof adhesive on a plastered wall.
hope this is of use.
tictic
Post by tictic »
you have to grout mate, you will have movement in the wall...when you apply addy..wet addy then its going to dry?so movement?
i thought you were talking about uncalibrated slate ere...just treat as mosiac! :wink:
Tim Robo
Post by Tim Robo »
Hi TicTic, Simon
Have posted some photos for your perusal. The mat is 300mm x 150mm
If I have to grout any suggestions as to the best, cleanest way.
cheers Tim
thescruff
Has thanked: 360 times
Been thanked: 3735 times
Post by thescruff »
To post a pic please read the FAQ in the forum index.
Tim Robo
Post by Tim Robo »
Hi Scruff,
Are the file sizes too big? if so how do I reduce to comply ?
Tim
thescruff
Post by thescruff »
No they were Zip files which could contain a virus, or unsuitable material.
You can attach photo's by following the how to in the forum.
Tim Robo
Post by Tim Robo »
I tried to send them the normal way but got a message to say the size was too big. Any ideas how to reduce them ?
thescruff
Post by thescruff »
Tim Robo wrote:I tried to send them the normal way but got a message to say the size was too big. Any ideas how to reduce them ?
If you look at the top of this forum index it will tell you how to re-size and post the pics.
Tim Robo
Post by Tim Robo »
Hi The scruff, tictic and Simon,
Got there in the end !!! I hope,
Same question really, the best way of sealing the small gaps where the tiles join.
cheers
bathroom 015.JPG (116.13 KiB) Viewed 2749 times
bathroom 012.JPG (95.16 KiB) Viewed 2749 times
Simon Site Manager
hi Tim,
I would of thought just some grey grout.
S
chris_h
Post by chris_h »
Agree with the grey grout.
Are the vertical edges meant to be in line as in pic 2 ??
Tim Robo
Post by Tim Robo »
Hi Chris,
yes, the straight vertical lines are the edge of the tile. The tiles are staggered, it's only the tile edges that need grouting the tiles are sealed at the back like mosaic.
thanks for your input, guys (good pic by the way Chris)
cheers
Tim
Return to “Tiling Forum”
