silicon that won't set!
Diy disaster stories in this forum please, Tradesmen disaster stories are also welcome in here!
Locked
micheemoo
Post by micheemoo »
I recently put some new silicon around my shower base and let it set for over 24 hours. I had a shower this morning and discovered that it is still soft and coming away from the wall!
Am I doing something wrong?
python
General Builder
Been thanked: 7 times
Post by python »
what brand of silicone was it?
critically, how think was the bead?
In normal circumstances, 24 hours should be ok, but there is never 'normal' circumstances.
Is it a new shower enclosure?
Were there any other chemicals in the area recently? (If you used a chemical aplication to remove old silicone, this may be a problem for instance).
Razor
Has thanked: 483 times
Been thanked: 1251 times
Post by Razor »
Was it silicone or was it marked up as bathroom sealant? Not the same thing I'm afraid :sad:
If it doesn't smell of vinegar I wouldn't use it :wink:
thescruff
Has thanked: 360 times
Been thanked: 3735 times
Post by thescruff »
Razor wrote:Was it silicone or was it marked up as bathroom sealant? Not the same thing I'm afraid :sad:
Might have used silicon grease :roll:
Has thanked: 1012 times
Been thanked: 918 times
Post by ultimatehandyman »
I once got some silicone and beaded around a window, then there was a knock at the door. I went and let my mate in and went to smooth it over and it had set :shock:
Has thanked: 734 times
Been thanked: 2335 times
decoraters caulk!!!
marc1106
Has thanked: 4 times
Been thanked: 49 times
Post by marc1106 »
guttering or poly sheet mastic probably :sad:
IF IT WERE EASY ITD B BORING!
royaloakcarpentry
Has thanked: 39 times
Been thanked: 621 times
Post by royaloakcarpentry »
Sounds like good old screwfix own brand.
handyman
Has thanked: 6 times
Been thanked: 11 times
Post by handyman »
did you use low modulus silicon by any chance? or bathroom sealant, not silicon?
Locked
Return to “DIY Disasters”
