WORX 850W Angle Grinder
Posted: Sat Apr 28, 2007 4:52 am
Bought this 6 months back but have never needed to use it so is still brand new.
It's still in the original outer box and complete with all the original accessories.
volts: 230v-50Hz
power input: 850W
no-load speed: 10000rpm
disc size: 115mm
weight: 2.6kg
spindle thread: M14
disc bore: 22.2mm
1 metal grinding disc
2 stone cutting disc
1 side handle
1 spanner
1 heavy duty carry case
£18 plus £5 for 48 hour delivery using a private courier (traking number supplied) or I can send by royal mails standard 3-5 working day service for £10.
I can take a photo if anyone's interested.
volts: 230v-50Hz
power input: 850W
disc size: 115mm
weight: 2.6kg
spindle thread: M14
disc bore: 22.2mm
1 side handle
1 spanner
