Wanted Metal Roofing Sheets
vfr800
Post by vfr800 »
WANTED
can anybody tell me where i can buy metal roofing sheets with the foam insulation already in thank you.
Scrit
Pro Cabinetmaker
Post by Scrit »
The sheets are profiled from pre-coated coil stock and then insulation is bonded to the underside. One of the few names I know of is Steadmans, but you could always try under "Cladding" in Yellow Pages as these profiles are generally sold as a building cladding system for commercial premises.
Scrit
Measure twice, cut once - except fingers!
Hitch
Has thanked: 77 times
Been thanked: 335 times
Post by Hitch »
They are called 'composite panel' sheets,
Polyester coated coloured outside and white inside sheet, with foam insulation between.
You can buy direct from coruspanel, or for smaller quantities try a local industrial/agricultural building contractor.
Where are you btw? If your in Devon i can help you...
Scrit
Pro Cabinetmaker
Post by Scrit »
In the dim and distant past when I worked for one of the Swedish steel makers we used to call them "Dobel" - catchy name, eh?
Scrit
-dj-
Been thanked: 1 time
Post by -dj- »
Return to “General DIY forum”
