Ccleaner
diyguys
Has thanked: 178 times
Been thanked: 19 times
Ccleaner
Post by diyguys »
What is Ccleaner,what does it do ,can you use it if you have norton 360 thanks.
chat_to_rich
Been thanked: 45 times
Post by chat_to_rich »
Ccleaner http://www.ccleaner.com/ is a cleanup utility you can use to remove unneeded files from your computer, e.g. Internet Explorer history and cookies. It can also cleanup your registry by removing unneeded keys. I'd be careful with registry optimisation as I found this page http://forum.piriform.com/index.php?showtopic=18859 where someone used the registry cleaner who had Norton 360 installed. Ccleaner had indicated an Norton regsitry key was "unidentified", when the person removed the key Norton 360 help no longer worked. Ccleaner can backup the registry before you remove any keys and this is something I'd definately recommend! Be careful with the Cleaner -> System section as "Empty Recycle Bin" is ticked by default, just in case you don't actually want to delete any of those files permanently. Dave.m has some Ccleaner instructions here ccleaner-setup-instructions-t20421.html
diyguys
Post by diyguys »
Thanks rich
Return to “Computers”
