Citroen Multispace 2l
Mick Coleman
Has thanked: 2 times
Post by Mick Coleman »
hi
i have a Citroen Multispace 2l diesel
i have a noise coming from the left hand side of the engin, around by the belts.
sounds like something rubbing or run dry, its 5 years old and 30000 on the clock.
could it be a lose belt??
thanks
PAINTER 1
Hitch
Has thanked: 77 times
Been thanked: 335 times
Post by Hitch »
Has one of the covers dislodged itself, so one of the belts rub on it...
Could be loads of things, rubbing noises are usually fairly easy to find...have you had a look?
Mick Coleman
cam belt
its coming from by the cam belt housing,
as if something has come lose
PAINTER 1
Hitch
Post by Hitch »
If nothing obvious outside of the housing, perhaps a quick look inside...?
Not sure if its easy to see inside...probably not.
How about the tensioner on the alternator belt...i have noticed a faint rumble from the one on my van, different engine, but i believe a few bits are shared.
Mick Coleman
you may be right
Hi thanks for the reply
i hope your right sounds like it may well be one of the things you said.
to much of a job for me i got no time (dark when i get home)
with only 30000 miles on clock i dont think its the engin.
thanks again
PAINTER 1
Sparky James
Has thanked: 8 times
Been thanked: 76 times
Post by Sparky James »
Get it checked out quick as if the cam belt comes off or breakes the engines toast.
Mick Coleman
asap
Yes
soon as i can
PAINTER 1
Mick Coleman
Gone
Hi
well its gone off to be repaired
let you know what was wrong
mick
PAINTER 1
Mick Coleman
alternator belt
Well done Hitch
My man says its the alternator belt £155 to put right
a service later on about £70 + parts
picked up car from home job sorted.
i know you could say £155 for a belt But he came out to me.
took car away sorted out my problem and gettin the car back to me next day.
with a report.
PAINTER 1
Hitch
Post by Hitch »
:thumbright:
