Kitchen Hinge Measurments
Hi Guys,
To start with, I am a newcomer to this forum and hope to use this forum alot in the future.
I dont if this has been asked already but when marking out to fit a kitchen hinge, how do i figure out where to drill my hole. Do i have to set the hinge to its max settings or min settings. Is there any websites that would show me.
Hope you guys can help
Cheers
Andy
Cheers
Andy
- Has thanked: 39 times
- Been thanked: 621 times
- Has thanked: 823 times
- Been thanked: 3559 times
Have a read of this http://www.woodfit.com/index.php?sid=82 ... &cPath=273
All the data you need
How thick is the door? This will affect the hinge mortice centre to allow the door to clear the carcase face.
There are lots of variables so the best way is to experiment on test pieces. If you fix the mounting plate end to a piece and then offer the door up you will get an idea of where it is. Some hinges allow you to make a mark through the centre point of the door mount.
- Has thanked: 4 times
- Been thanked: 49 times
i have 2 of these in the van and they really are a blinding tools to have!
http://www.wolfcraft.de/jcatalog_genera ... oduct.html
IF IT WERE EASY ITD B BORING!
