Ceramic tiles around wood framed bathroom window
andy68
Post by andy68 »
Help! I'm sure this has been asked a million times but I can't find anything that solves my problem.
We've just re-tiled our bathroom, including on all four sides of the window recess which had a wooden inset surround. Two days later the tiles have lost contact with the wood and the ones at the top (ie hanging down) have actually fallen off. I have read some advice that says use diluted PVA and some that says definately don't and use a solvent based primer - which is right? There isn't enough space to add a layer of aqaupanel because all the other tiles would be out of line.
What do I do? Any ideas welcome (apart from take 'em all off and start again!)
many thanks
royaloakcarpentry
Has thanked: 39 times
Been thanked: 621 times
Post by royaloakcarpentry »
Can you not take the surround out and then put plasterboard in?
Other option is to put expanded metal lathe over the timber and tile onto that.
oohhh unlike me, but you could bodge it......gripfill or silicon them on.
Only-Me
Been thanked: 3 times
Post by Only-Me »
Is the wood varnished/painted?
Wot cement was used??
andy68
Post by andy68 »
yes, the wood was varnished and I used unibond allpurpose tile on walls adhesive and grout.
I'd thought of the 'no more nails' option but the bead would be too thin I think for the tiles.
thanks for replies so far.
lewcrippen12
Post by lewcrippen12 »
Hi guys,
Solvent based primer would be better as it's quality based.Well for any another help for home can use kitchen cabinet replacement,here u can find more things for u r home.
Regards
Lew Crippen
Kitchen Cabinet Replacement
wine~o
Has thanked: 1414 times
Been thanked: 4019 times
Post by wine~o »
Spam,,, :roll: :roll:
Return to “Tiling Forum”
