Hi
I can't figure out a way or tiling above a window.
The piece I am talking about is the vertical wall above the window and below the ceiling - not the "ceiling"/horizontal part of the window recess.
My problem is: how to keep the tiles from slipping down the wall. I could put a baton straddling the window but I don't think I have ever seen anything like that in the DIY books.
Is there a better way of doing this?
thanks
I couldn't do this stuff without your help.
- Mooncat
- Has thanked: 81 times
- Been thanked: 72 times
This is what I did for both under hang, and the row on the wall.
- Mooncat
Yes. Using two struts makes it easier to adjust the tightness, and fastening the pieces with screws helps a lot when working on your own. The joints worked out exactly at the top of the window, not that it mattered here as the corner is now hidden behind a roller blind.
