Laptop keyboard question
Mooncat
Has thanked: 81 times
Been thanked: 72 times
Post by Mooncat »
The Lady M's Samsung laptop has developed a fault where some keys have to pressed harder than normal to get them to work. Is it possible to remove the keys individually as you can with a desktop keyboard, or is it a dismantle job?
mikew1972
Has thanked: 10 times
Been thanked: 110 times
Post by mikew1972 »
You can remove the individual keys on most laptops as you can on a regular keyboard but, like on a regular keyboard it usually does not give you access to the 'switch' that the key operates as this is sealed under a sheet of rubber / plastic to protect the 'switch' from debris and spills so won't really help. I'm afraid you are probably looking at replacing the keyboard if you have already tried blowing / vacuming out any debris from between the keys and this has not helped.
Check on ebay for the cost of a replacement keyboard for your model there are loads of companies on there offering new and used laptop components.
Mike
philips9071
Post by philips9071 »
You could probably remove the keyboard to clean it out - remove all the screws from the underside, plus also check under and facia plates under the screen (in case there's any extra screws under there - they've caught me out before!). If a good clean doesn't do the trick, then as mikew1972 says, spare parts are cheap and easy on ebay.
Has thanked: 735 times
Been thanked: 2339 times
try turning up side down and shaking you will be amazed at what falls out
kellys_eye
Has thanked: 357 times
Been thanked: 1790 times
Post by kellys_eye »
Most laptop keyboards are a 'sandwich' construction which, apart from allowing you to remove/replace keycaps, are virtually impossible to disassemble for cleaning or repair.
Replacement would be far less stressful.
Return to “Computers”
