- It is currently Mon Apr 14, 2025 11:59 pm
drilling 30mm holes in Aluminium and S'Steel
Hello everyone I'm new here and in need of some guidance.
I have to drill a 30mm hole in 4mm thick brushed stainless steel sheet and the same in 4mm think brushed aluminium sheet
I have access to a pillar drill and a hand drill.
What type of drill bit should I use, will a Bosch 30mm hole saw do the job? are there any special hints and tips you can offer for a 1st attempt. I dont really want (can't afford) to get this wrong.
Any advice here would be most welcome.
Thanks very much
Graham.
Thanks very much
Graham.
gthang
- Has thanked: 4 times
- Been thanked: 49 times
http://www.google.co.uk/products?source ... CCQQrQQwAg
try somthing like this obviously you have to find the right size!
IF IT WERE EASY ITD B BORING!
marc1106
Bob225
gthang
- Has thanked: 77 times
- Been thanked: 335 times
You wont have much sucess on 4mm thick stainless with a step drill. They are okay for sheet, but not very good on plate.
I would buy a bahco or starret hole saw and arbour. Dont bother with Bosch if its the quick release ones you are looking at.
Drill the aluminium first, than the stainless.
Centre punch the hole, drill the pilot hole with an ordinary bit first, same size as the pilot in the holesaw arbour.
That way you can control the holesaw, putting very little pressure on it untill it has started properly.
Dont run the drill too fast. Use cutting oil on the stainless, not WD40. Some engine/gear oil will be better than wd40.
If you go too fast, you will harden the stainless and kill the holesaw. Then you will have a job on your hands!
Easy if you know what you are doing.
Just remember, keep the bit running fairly slow, but a fair bit of pressure. If your drill seems to run too fast, pull the trigger on and off.
Have a look here...
http://www.ultimatehandyman.co.uk/DIY_M ... hnique.htm
Have a look here...
Hitch
- Has thanked: 63 times
- Been thanked: 59 times
I'd use the pillar drill and a hole saw.
G-clamp the work piece to the drill table if possible, using a piece of wood to protect the job. Any excess vibration will only hinder progress and lead to (more) grabbing.
As already mentioned, slow speeds with moderate pressure and use coolant.
The stainless hole will be painful
wrinx
wrinx
wrinx
- thescruff
- Has thanked: 360 times
- Been thanked: 3735 times
thescruff
Hitch
- thescruff
thescruff
Stoday
- Has thanked: 8 times
- Been thanked: 76 times
Post by Sparky James »
Agreed with the old un centrpunching SS can cause all sorts of problems with work hardening.Stoday wrote:Interesting, Scruff, especially the note that centre punching austenitic SS can result in local work hardening that can cause the drill to blunt.
We work on a lot of SS food machinery and the best thing is loads of cutting oil and going slow with tip top hole saws dont be tempted to use a cheep saw or one thats done much work.
Sparky James
Hitch
Bob225
wrinx
Don't centre punch, use a cetre drill to start the holes. Like this
http://www2.westfalia.net/shops/tools/d ... 0ccf4ae860
You'll pick one up on carboots or Ebay really cheaply and they are essential for accurate drilling of metal really...and tough. :)
Parafin is a better coolant/ lubricant that WD40 too.
timmmers
