First house project
- Crooksey
- Been thanked: 72 times
First house project
Just exchanged on my first house and get the keys tommorow (hopefully) :).
I decided togo for a wreck of a 3bedroom, rather than a swanky new 1bedroom place.
Its got 3 bedrooms (end of terrace), big kitchen and a massive garden with shed and garage!.
It needs literally everything doing, first off I will list what tradesmen will be doing...
1. Removing backboiler from lounge and fitting a combi boiler in the loft
2. Replacing all windows and doors
Thats about it, the work I plan to be doing (with mates and dad) is...
1. Partial re-wire with new consumer unit (just ordered £350 quids worth of supplies!) I have gone for superswitch sockets etc for a better finish.
2. New kitchen (purchased)
3. New bathroom (purchased)
4. Every room has either woodchip or artex on the walls, so this needs to be stripped.
5. New carpet all over (allthough there are real wood floorboards that are mint, I could sand theese in some areas.
6. Replace all doors and architraves (and skirting)
7. Knockout a few cupboards
8. Landscape garden and build a new shed.
Thats about it.... (famous last words)
I hope the house will be in a state that I can move into in about 2 months.
Will add pictures at as many stages I can, any advice welcome anytime.
- thescruff
- Has thanked: 360 times
- Been thanked: 3735 times
- big-all
- Pro Carpenter
- Has thanked: 734 times
- Been thanked: 2336 times
- Has thanked: 39 times
- Been thanked: 621 times
Think carefully about positions of socket outlets so you can arrange furniture around the room in different layouts. You can never have too many sockets, in my opinion.
Ask tradesmen if they mind you giving them a hand....good way to learn and a bloke who knows his stuff will be only too happy to have you watching or helping as long as it doesn't slow him down.
Right about sockets - you can never have too much!!
Our house -
4 sockets in each room (1 in each corner). Extra near the TV
TV in every room
Phone socket in selected rooms.
MK outdoor sockets at the back and front of the house. Power to the sockets is cut off by a switch inside the house. Don't want anyone stealing my electricity!!
If we were to re-wire the house again I would go for double CAT 5 in every room as well.
Artex -
We had artex. Don't try stripping it - takes too long. Easier to get a plasterer and skim over.
All the best.
Our house -
TV in every room
Artex -
All the best.
- Crooksey
Some progress...
A partial re-wire has turned into a full house re-wire, due to the shoddy state of the electrics. (found one capped of sockets with raw plugs over live wires).
The house has had one elderly owner since new and has had no work whatsoever done to it. So all I can assume is shoddy contractors in the days before part P.
Kitchen ring main is complete now, and from 1 2 gang socket I now have 6 in the kitchen.
Next job is lounge/hall, then a full re-wire of upstairs.
Im so lucky to have decent neighbours, bloke next door has plugged extension lead in so i can have kettle/torch plugged into mains.
Only a few hours to put in today because of mothers day, so I will upload loads of pictures of the work.
- Crooksey
its my first place and im lacking in funds.vinesh wrote:Right about sockets - you can never have too much!!
Where my office is, it will have a phone point, and I have a wireless router that I have customised into a rane extender with 4 ethernet ports, which will form the cat 5 ports for TV/PC area. That cost me £20 for router and used free DD-wrt firmware, dead cheap, easy to install and can be moved from room to room and house to house.
Rane - is that the same as the powerline plugs?Crooksey wrote:its my first place and im lacking in funds.vinesh wrote:Right about sockets - you can never have too much!!
DD-wrt firmware - interesting. I'm doing some reading on this.
I will have to look into this for my home.
- Mr. Grumpy
- Has thanked: 25 times
- Been thanked: 109 times
For wiring I added phone sockets, Cat6, 3 Sat cables and in all rooms. Use modular face plates and even if you don't want them you can leave the wire behind the face plate (within reason). All cables run back to a central point
Material is not that expensive, work is in putting it in as as you are taking boards up you might as well do it I will never use all the cables but never sure who uses what room in the future
BY will charge 150 to run a phone line into your house. Putting in sat cables afterwards looks bad unless you can hind them properly
SACRAMENTO..............that was a proper kitchen built with love and tenderness by a carpenter and you killed it. Don't get them like that any more. lol
Well worth doing full rewire anyway and giving the old plumbing the once over. Nothing worse than doing a house and then having to rip flooring up 5 years later to rewire and sort plumbing.
