garden lights
frankiecam13
garden lights
Post by frankiecam13 »
hi m8s can anyone 1 recommend some garden spotlights electric about 4 or 5 to cove a length of 12m i have a outside socket to connect them
thanks
mikew1972
Has thanked: 11 times
Been thanked: 110 times
Post by mikew1972 »
Are you lighting a path or something wider like a driveway? How much light do you need? Do you need to just define the edges? (solar powered) or light it up so you can see uneven raised stones or similar? (mains powered low voltage) or light it up like daylight? (mains voltage garden lamps)
Mike
frankiecam13
just to highlite plants and bushes
mikew1972
Post by mikew1972 »
Right, OK. I think thats the solar powered ones out as they are not bright enough.
Probably the cheapest and easiest option is these:
http://www.****.com/pr ... 207?tkt=fr
B&Q sell them, or used to at about the same price but I can't find them on their unusable website.
My brother hites out marquees and uses these to light the sides of the marquee from the outside. They last a couple of years (though use a lot of bulbs) being thrown in and out of the back of a lorry.
You can wire them up with flex to a plug in your waterproof socket and daisy chain one from another so you only need 1 socket.
Mike
frankiecam13
ok thanks m8
Return to “Gardeners World”
