Power steering fluid
Old Vinyl
Has thanked: 17 times
Post by Old Vinyl »
Is it the same as brake fluid? Or do I need to buy it specifically?
:oops:
Renault Laguna Estate
speed
Has thanked: 35 times
Been thanked: 257 times
Post by speed »
dont use brake fluid
you need to get some proper stuff halfords sell it as
Automatic Transmission and Power Steering Fluid
mikew1972
Has thanked: 11 times
Been thanked: 110 times
Post by mikew1972 »
Second that. It might look the same and do a similar job but they do not mix and even if you were to drain and flush the system with the other stuff the seals are made of a different material. PS fluid rots brake cylinder seals and brake fluid rots PS seals.
Ask me how I know. :oops:
Mike
Old Vinyl
Post by Old Vinyl »
Ok thanks, I'll buy some of the proper stuff, thought I could save a few quid by using brake fluid :wink:
Hitch
Has thanked: 77 times
Been thanked: 335 times
Post by Hitch »
I expect brake fluid to be dearer than PAS/ATX fluid. :wink:
Old Vinyl
Post by Old Vinyl »
Sorry, I meant I already have brake fluid here in the cellar.
Well, just bought the right stuff, it's Power Steering [b]and[/b] Automatic Transmission fluid, I thought these fluids were dual purpose somewhere along the line :wink: .
thescruff
Has thanked: 360 times
Been thanked: 3735 times
Post by thescruff »
If you're storing stuff like brake fluid, remember it degrades over time, picks up moisture, making it next to dangerous to use once opened.
Hitch
Post by Hitch »
Hydroscopic is the term Scruff. :thumbright:
Old Vinyl
Post by Old Vinyl »
Oh, ok thanks. :thumbright:
