Floor tiles over laminate flooring in bathroom
As the title suggests I am about to start ceramic tiling in the bathroom which has wooden flooring over which is sound laminate. Is it ok to merely fix the tiles over the laminate - ? - if not why not ?
- big-all
- Pro Carpenter
- Has thanked: 735 times
- Been thanked: 2340 times
- Mr. Grumpy
- Has thanked: 25 times
- Been thanked: 109 times
- Has thanked: 6 times
- Been thanked: 11 times
Adhesive might not stick to the plastic surface very well. The laminate is floating, so the tiles will also float, and the movement may well stress the tiles, as the tiles surface will be closer to the skirting than the expansion gap of the laminate. The laminate will have insulation under it, so laminate/insulation will have movement, which will also result in the grout/adhesive failing.
You take laminate up, and replace with cement board or ply screwed down, then tile on that. Doing anything that includes the laminate will just be a daft thing to do.
- Mr. Grumpy
- Has thanked: 4 times
- Been thanked: 49 times
losgiganteskid wrote:I wanted to leave it down cos its in good condition and would provide a sound smooth surface upon which to lay the tiles. The sub floor is ordinary floorboards, which are not as flat as the existing top laminate.
I'm very tempted to leave the laminate - what is the likely consequence if any of that
the laminate is what is known as "FLOATING" therefore is deflects when you walk on it! when tiled floors deflect they debond and lift therefore they dont stay down!
as someone else said remove the laminate then lay 6m hardibacker or equivalent, then tile to that!
IF IT WERE EASY ITD B BORING!
- thescruff
- Has thanked: 360 times
- Been thanked: 3735 times
As an experiment I applied some tile adhesive (for wood) on the laminate 48 hrs ago and it has set and stuck to the laminate well and took a bit of shifting to remove it so I guess your therory of it not adhereing to the laminate is not correct !handyman wrote:Adhesive might not stick to the plastic surface very well.
- Razor
- Has thanked: 483 times
- Been thanked: 1251 times
- Has thanked: 5 times
- Been thanked: 23 times
am still pmsl...at this thread, from your first one to this...losgiganteskid wrote:As an experiment I applied some tile adhesive (for wood) on the laminate 48 hrs ago and it has set and stuck to the laminate well and took a bit of shifting to remove it so I guess your therory of it not adhereing to the laminate is not correct !handyman wrote:Adhesive might not stick to the plastic surface very well.
this adhesive did it come in a bag or tub??
you have been givin THE CORRECT advise on this forum and other forum regarding on what you propose to do...
so if you dont take the advise givin to you.
THEN GO AHEAD AND TILE OVER YOUR LAMINATE BUD
