Shower enclosure door fitting
Hi, could do with some advice. Have had a solid stone/resin shower tray fitted. I am planning on tiling myself. Is it best to tile past the tray slightly so the shower door can be fitted? also whats the recomeded adhesive and grout I should purchase. Am going to leave a 2mm gap from tray to tile for sealing. Is it ok to leave a 2mm grouting space between tiles or should this be wider? any info would be much appreciated.
- Has thanked: 5 times
- Been thanked: 23 times
if your only tiling round the tray?..imo tile to edge of tray.
is it a door/partition/screen/enclosure should have fitting instructions.
adhesive/grout..what size/thickness/type of tile are you fixing.?
spacer again size of tiles.? and personal preferance(dont go lower than 2mm..BS standard)
yes leave 2-3mm gap between tray and bottom course off tiles.
