Adobe error 1500
thescruff
Has thanked: 360 times
Been thanked: 3735 times
Adobe error 1500
Post by thescruff »
Went to install the latest update and got the message.
Install failed, go to Adobe repair.
error 1500.
this is caused by an error in the registry, if you run a prog like Registry fix and repair any problem, Adobe update works.
dave.m
Deceased 07-06-2012 R.I.P
Has thanked: 13 times
Been thanked: 318 times
Post by dave.m »
Thanks for the pointer, John.
Out of interest:
Do you just use the Adobe Reader for opening PDF files?
Or do you have the paid version for Creating/Editing PDFs?
The free Foxit Reader is a good replacement for the basic Adobe Reader. It uses much less resources and does the same job.
dave
But you cannot tell him much.
thescruff
Post by thescruff »
Actually using Adobe 8 at the moment, but the error 1500 problem is with all the versions.
Yes, use it for opening PDF.
gas4you
Has thanked: 419 times
Been thanked: 900 times
Post by gas4you »
I've not had any update problems. I have 9.xx and the full paid for version with CS4 Design suite.
I use it for creating pdf's to send on to customers.
Dave
thescruff
Post by thescruff »
Loads have though.
Do a google and see. :thumbright:
Inky Pete
Has thanked: 12 times
Been thanked: 161 times
Post by Inky Pete »
I tried the update once and got the 1500 error.
Then tried it again a couple of days later and it went through fine.
Return to “Computers”
