Hi All,
I recently had my kitchen floor tiled. The house is pretty old and hence some floors are quite uneven / sloping slightly.
There are a couple of the tiles that feel a bit loose when I walk on them, but so far everything looks OK. I.e grouting is not cracked or anything.
Is there anything I can do to stop these feeling loose/wobbly?
Thanks!
Laura
new tiles on uneven surface - a bit wobbly!
- Has thanked: 5 times
- Been thanked: 23 times
few ?..first..
did you employ someone to fix tiles,if so get them back to have a look.
now could be a number off things..
movement in the substrate..
is it a timber floor that has been overboarded with wbp ply or a backerboard.
concrtete floor,was it primed proir to fixing..(dust on floor so adhesive not bonding)
voids under the tiles..(not enough adhesive under tile)
