Google toolbar history deleting
- Has thanked: 178 times
- Been thanked: 19 times
How do you clear your search history on google tool bar,i have highlighted and pressed the red x for delete but when i go back it has not deleted cheers.
- dave.m
- Deceased 07-06-2012 R.I.P
- Has thanked: 13 times
- Been thanked: 318 times
Re: Google toolbar history deleting
But you cannot tell him much.
Still no good i think that is for the old version?I dont have a toolbar wrench icon,i think this is a common problem with ie.I think this is ie 8 how do i unstall it and go back to ie7 cheers
-- Sat Apr 24, 2010 4:32 pm --
Uninstalled ie8 and reinstalled it now my talktalk homepage has vanished, how do i get it back fn computers .
- dave.m
Why on earth uninstall your browser to just try to get rid of search history in a toolbar?Uninstalled ie8 and reinstalled it now my talktalk homepage has vanished, how do i get it back fn computers .
First thing to do to get your homepage back is to do a system restore to back when your homepage was showing.
If the link (above) did not help (which it should have done if you had not jumped the gun and gone too far):
Then uninstall the Google toolbar:
http://www.google.com/support/toolbar/b ... nswer=9231
After that, you can reinstall it and set it to what you want.
Hi dave i uninstalled it because it said on the web that if you cannot delete your toolbar history the browser may have been hijacked,also on my norton the antiphishing was turned off not by me.When i usually start up it goes straight to the talktalk page but now it doesnt,it goes to google default igoogle.
- dave.m
Uninstalling IE8 on a computer that HAD IE7 and was updated, will simply revert you back to IE7, and if the browser was hijacked, then the older version will be also.
We have two different things going here, one is your search history that you want deleting and the other is a possible infected browser.
Starting with the second problem:
download MalwareBytes' AntiMalware using the BLUE button for the FREE version.
* Double-click mbam-setup.exe and follow the prompts to install the program.
* At the end, be sure a checkmark is placed next to the following:
o Update Malwarebytes' Anti-Malware
o Launch Malwarebytes' Anti-Malware
* Then click Finish
If an update is found, it will download and install the latest version.
* Once the program has loaded, select > Perform Quick Scan, then click > Scan.
* When the scan is complete, click > OK, then > Show Results to view the results.
* Be sure that everything is checked, and click > Remove Selected.
* When completed, a log will open in Notepad. Save this log to My Documents in case it is needed for reference.
Reboot as required.
Do this and then we can see what the problem is with the toolbar.
dave
* Then click Finish
Reboot as required.
dave
Dave it went tits up done system restore went back to a date when running ok then the page kept saying conf updates for about five hours and wouldnt let me back on the computer so had to run repair disc and wiped the hardrive to install again . I am trying to get the page where it has files etc on top left hand corner.Is ther any way i can get files back that were wiped from the hard drive cheers.
- dave.m
When you say the "Files etc in the top left" I assume you mean the Menu Bar in your browser. If so, right click any empty space at the top of the screen and you should get a context menu with:
Menu Bar
Navigation Bar
Customize
Tick Menu Bar and it should re-appear.
Try Recuva from the makers of Ccleaner
dave
Menu Bar
Navigation Bar
Customize
As for recoverying your files, it depends upon what the recovery disk overwrote.Is ther any way i can get files back that were wiped from the hard drive cheers.
dave
- thescruff
- Has thanked: 360 times
- Been thanked: 3735 times
I am trying to get files,view fav tools help that use to be at the top left corner so i can finish reinstalling norton i need the file section cheers,i have reinstalled winpatrol and mal
-- Sun Apr 25, 2010 2:20 pm --
-- Sun Apr 25, 2010 2:27 pm -- done the recover scan nothing found,deep scan takes an hour do i have to be connected to the internet when it doing this cheers.
-- Sun Apr 25, 2010 2:53 pm --
When i used the recovery dvd i recovered windows to the first partition only,it says this option will delete only the first partition, allowing you to keep other partitions,and create a new system partition as drive c what ever that means.
-- Sun Apr 25, 2010 3:31 pm --
The problem with me as dave has said i jump the gun.thescruff wrote:I hope you haven't lost the welding How too
What i have noticed is since i have reinstalled the email key works ,before i had to press arrow up and 2 Is there anything else i should do dave,looks like all this security software doesnt protect your systems that well .Do you think i did the right chose when i installed to the first partition only cheersdiyguys wrote:I am trying to get files,view fav tools help that use to be at the top left corner so i can finish reinstalling norton i need the file section cheers,i have reinstalled winpatrol and mal
- dave.m
Sorry, been off line all afternoon and evening, family round for dinner and a game of cards. (Not Happy Families)
Let's start again.
"I am trying to get files,view fav tools help that use to be at the top left corner "
You mean the Menu Bar but in what program, because the Menu bar appears in browsers, and all sorts of application windows.
Which 'window' is it missing from? The browser or an application like Word or something.
If it is missing from the browser, did you rigt click on an empty part of the Address bar? If so what did the menu say.
What operating system do you have, XP, Vista or Windows 7
What browser do you now have, IE7 or IE8
Why do you need the file dropdown menu to install Norton.
"Do you think i did the right chose when i installed to the first partition only"
What do you mean by that? When you installed WHAT to the first partition?
dave
-- Mon Apr 26, 2010 3:35 pm --
I've re-read your last post and see that you put the OS onto partition C:, which is where it should go, so that bit is OK.
any further reports as to what is happening?
dave
Let's start again.
dave
dave
Hi dave the recover files didnt work only a few came back but they where fkd,a lesson for everyone to copy all your files cheers.dave.m wrote:Sorry, been off line all afternoon and evening, family round for dinner and a game of cards. (Not Happy Families)
Let's start again.
dave
dave
