Some Computer Tips From Microsoft.
Posted: Wed Apr 28, 2010 12:07 pm
Clean your computer
Dust clogs the vents behind your computer, which causes your CPU to heat up—and heat is the biggest cause of component failure in computers. Regular cleaning could save you costly maintenance fees down the road.
Keep your computer in tip-top shape by following Millman's guide to a spotless computer system.
10 Ways to Tune up Your PC
Everything needs a tune up: cars, pianos—even your computer! Here are ten ways for you to tune up your PC to help keep it running smoothly and efficiently.
Speed up your PC
Are you sure that you're getting the very best performance out of your PC? Whether you're running Windows Vista or Windows 7, try these tips to give your PC a little extra zip.
Windows 7 Disk Cleanup Utility
Are you looking to free up a few megabytes of space on your hard drive? Then you should check out Windows 7’s handy disk cleanup utility.
Clean your computer
Speed up your PC
