tile trim
- Cantseeitfrommyhouse
- Has thanked: 36 times
- Been thanked: 108 times
Re: tile trim
There's usually a selection of upvc edge trims available at B&Q and the like. Perhaps an angle bead.
- These users thanked the author Cantseeitfrommyhouse for the post:
- 214kim
- 54aardvark
- Has thanked: 16 times
- Been thanked: 56 times
Re: tile trim
Decorated a kitchen last year, someone else had done the tiling and hadn't used tile bead, just the usual fingerful of grout run along the edges - looked awful and from decorating point of view no specific straight edge to work to.
Carefully raked back the grout and managed to get a groove a couple of mil deep behind the tiles, got normal tile bead and trimmed back the lip so it just fitted behind the tiles and then fixed with Gripfil - still there a year later. Have done this a few times since with good results, unconventional but makes a much better looking job.
I get really pi**ed off when folk don't use trim.
There are no problems - only solutions
- Has thanked: 39 times
- Been thanked: 621 times
Re: tile trim
If tiles are not full height up walls then you don't need a tile trim. It is how you finish that determines what looks good/bad, leaves a good/bad edge for decorating.
Certainly shouldn't be running a grout line along the top with a finger, just as you shouldn't run silicone or caulking along the top with a finger.
Tooled caulk or silicone joint, back of tiles infilled with flush grout joint all make for acceptable finish to paint to.
