Worktop edging strip
Locked
juandan
Post by juandan »
Hi, can you tell me the best adhesive for putting the edging strip on the end of the worktop, I've been using PVA adhesive and sealer I have to use a weight on the strip and leave it for a few hours to make it stick I was told to use it by B&Q I now have a 2m length so I can't put a weight on the end of that
panlid
Been thanked: 1 time
Post by panlid »
i just use impact adhesive.
juandan
Post by juandan »
can give me a name?
panlid
Post by panlid »
juandan
Post by juandan »
Thanks for the reply Panlid, but its a bit expensive £2.99 for the adhesive and £5.95 for packing and handling I can get it local for £4.99 but thanks for telling me the name of the adhesive
skiking
Been thanked: 4 times
Post by skiking »
Try B&Q - they sell it as well altho' a little pricier (improved version :?) plus they do a tube for less than a couple of quid.
panlid
Post by panlid »
dont get solvent free. imo it is crap.
peteyweakstraw
Post by peteyweakstraw »
If you're looking for an adhesive, you should probably use Scotch-Weld Urethane Adhesive. It has two parts in it that makes it resistant to the cold and heat. This is a wonderful product that has long lasting durability.
Locked
Return to “Kitchen Fitting”
