Bike Shed
- Has thanked: 7 times
- Been thanked: 51 times
Bike Shed
I've been meaning to do this one for a while and I finally got a bit of free time and a pile of offcuts from a fencing job. We needed somewhere to lock up the boy's moped and some pushbikes and we had a pile of shrubbery around a yew tree in the front garden near the front door. It needed some thinning out so we decided to take out the yew and leave the shrubs at the front. This would leave a suitable space behind the shrubs to pop in a covered area for the bikes.
Due to the limitations imposed by the lengths of the offcuts, I had to make the roof a bit more complex than I would have liked.
I'm waiting for some leftover ballast from the next job to lay a concrete floor and set in the bike rack and the securing post for the moped. Apart from that, it just needs a bit of felt for the roof and it will be finished.
- The stump of the yew tree.
- bike shed 003.jpg (104.91 KiB) Viewed 4079 times
- bike shed 005.jpg (103.86 KiB) Viewed 4079 times
- bike shed 006.jpg (102.11 KiB) Viewed 4079 times
- bike shed 008.jpg (81.68 KiB) Viewed 4079 times
- bike shed 101.jpg (92.44 KiB) Viewed 4079 times
- bike shed 102.jpg (102.13 KiB) Viewed 4079 times
- bike shed 103.jpg (85.21 KiB) Viewed 4079 times
- The view from the road, showing (or not showing) how the bike shed is hidden.
- bike shed 106.jpg (130.49 KiB) Viewed 4079 times
Phil
Advise rhymes with rise. Advice rhymes with rice.
- wine~o
- Has thanked: 1414 times
- Been thanked: 4015 times
Re: Bike Shed
Looking good
- Has thanked: 178 times
- Been thanked: 19 times
Re: Bike Shed
Hi geewizz ,looks great ,how did you mearsure mark out the hip rafter?,are you going to felt the roof.What are you going to use to preserve the timber?
- thescruff
- Has thanked: 360 times
- Been thanked: 3735 times
- big-all
- Pro Carpenter
- Has thanked: 734 times
- Been thanked: 2336 times
Re: Bike Shed
excelent job
just seems a lot off trouble to go to just to let you have a crafty fag or a quick grope behind it
- thescruff
Re: Bike Shed
diyguys, I would love to tell you how I made the hip rafter but, truth is, I don't know what one of those is. All the timber is pressure treated and the sawn ends have been given a lick of clear wood preservative.
Big-All, you're the second person today who has voiced suspicions about the true motive for building this. I have to admit, it will make a great little sanctuary for the odd fly smoke.
thescruff, yeah, I agree about it NOT looking good And, you're right about that yew stump. It put up a rare fight. I gave it some dignity by taking a photo of it's last stand before i humphed it off to the tip.
- bike shed 004.jpg (97.25 KiB) Viewed 4018 times
Phil
- Jaeger_S2k
- Pro Handyman
- Has thanked: 20 times
- Been thanked: 27 times
Re: Bike Shed
With a pencil!diyguys wrote:how did you mearsure mark out the hip rafter?
Jaeger.
Re: Bike Shed
Although Jaeger_S2k's response might look a bit flippant, he's spot on.diyguys wrote:Hi geewizz ,i am talking about the rafters that are at the far end of the shed that are cut at 45 degrees to the normal common rafters,fourth photo down.
I had the ridge piece in place, ontop of the two A shaped bits. All I did was balance a bit of wood across the point of the A and thecorner post and then draw vertical lines with a pencil on a spirit level to mark where the joints would need cut.
By the way, the shed isn't square. I laid it out so that the front is wider than the back. Also, the sides are different lengths because of the way the path at the front lies and the way the fence runs. To make the best use of the space and to provide adequate access I had to drop any ideas of slapping in any right angles right at the outset. So every piece had to be measured and cut individually.
Phil
- Has thanked: 807 times
- Been thanked: 3500 times
Re: Bike Shed
Nice job Phil, it looks like a typical design as you go job that we all do . May I suggest that you fabricate some steel loops to bed in the concrete mix so you have some good strong chaining points for the bikes.
- Jaeger_S2k
- Pro Handyman
Re: Bike Shed
It was a double edged sword that one, it seemed flippant but it's how I would have done it, place and mark with a pencil.Geewizz wrote:Although Jaeger_S2k's response might look a bit flippant, he's spot on.diyguys wrote:Hi geewizz ,i am talking about the rafters that are at the far end of the shed that are cut at 45 degrees to the normal common rafters,fourth photo down.
That's a good idea DWD, security at it's best, but don't be surprised if you come home and find the slab missing
Jaeger.
Re: Bike Shed
I would certainly be surprised if I came home and found the slab missing. It will weigh somewhere in the region of 800kg.
Thanks DWD,
I'm putting in a security post in a lump of concrete under the concrete floor for chaining up the moped. The back of the shed was measured to accommodate a bike stand which takes 5 bikes. This will be bolted into the concrete floor. If anyone manages to steal a bike from that lot without getting caught then they're welcome to it.
Thanks DWD,
Phil
- Has thanked: 39 times
- Been thanked: 621 times
