Stone slab - Best fixing option
Kabous
Has thanked: 7 times
Been thanked: 3 times
Post by Kabous »
I want to lay a 600mm x 600mm solid/ one piece stone or slate paving slab outside on to a concrete slab.
Which will be the best option and how would I fix it on to the smooth concrete slab?
Any issues that I need to consider i.e weathering, sealing etc?
As always comments and suggestions greatly appreciated.
Geewizz
Been thanked: 51 times
Re: Stone slab - Best fixing option
Post by Geewizz »
For the small quantity you would require, your easiest option would be to pick up a bag of premix mortar and add water.
How smooth is the slab you are laying on? If it is polished concrete then you might need to rough up the surface a bit for the mortar to adhere. I would make a few cuts across it with an angle grinder.
Phil
Advise rhymes with rise. Advice rhymes with rice.
Return to “Tiling Forum”
