Sub Floor Extractor Fans?
- Has thanked: 7 times
Does anyone know if I can buy a kit to replace a brick or existing air brick with a vent including a low voltage fan so I can extract some of the moist musty air from within the crawl space of my home?
N
N
- thescruff
- Has thanked: 360 times
- Been thanked: 3735 times
Re: Sub Floor Extractor Fans?
I tried that but the only things that looked suitable are in Australia. It seems big there for some reason.
Will keep looking but Ive just found bathroom and kitchen fans so far. I was thinking of something that was a direct replacement for an airbrick - single or double. And, low voltage - like 12V DC or something.
Any thoughts?
N
Any thoughts?
N
- thescruff
The low voltage fan would be the only problem I see.
Ask this guy, he's one off our advertisers, you should get a discount if you mention UHM.
http://www.fastlec.co.uk/extractor-fan- ... -1822.html
Actually there quite a few 12v Extractor fans about.
Do a google for low voltage extractor fans.
I like it but I need to drop down because of the cavity. Where would the fan go?
I think I like the idea of the fan being in the wall as when it dies, which it will at some point, I dont have to get the flooring up - I just drill and chisel it out in 15 minutes.
Am I being daft?
Am I being daft?
- thescruff
Ask http://www.fastlec.co.uk/ what they have. thats why here on here to answer questions.
You can always duct and have a trap in the floor, I see there's plenty of 12v fans about that would normally have a transformer.
Your plan looks good.
- Has thanked: 8 times
- Been thanked: 76 times
Hows about posative pressure ventilation, if the boards are good and reasonably airtight it would give better all over air movement.
Hi Sparky. Not sure how you mean. Do you mean like taking air from outside and pushing it into the sub floor? If so that I can see how air would get to places that a negative air pressure approach wouldn't. But my worry is all the many gaps everywhere that having a higher pressure in the sub floor would mean that the stale air is dying to get out and into the house above?
Cheers
Cheers
- moderator2
- UHM Super Moderator
- Has thanked: 155 times
- Been thanked: 569 times
Misskerry, Please don't dig up 10+ year old threads. None of the people in this thread have posted for a long time. I've locked the thread.
