Floor tile removal
Posted: Wed Aug 04, 2010 8:43 am
My underfloor heating has stopped working: Ive a feeling I cut the cable whilst removing the silicon that the 'tiler' (for want of a better description) did as he used the wrong colour. Having removed it all and redoing it with the correct colour I discovered that the underfloor heating has ceased working. Its the electric type (http://www.ambient-ufh.co.uk/under-tile ... -c-42.html), and repair kits are available.
The question is this. Ive an idea where the fault will be - fortunately it can only be near the wall/floor edge so its a case of lifting the 'cut' tiles around the edge, and/or just two 'complete' tiles off to one side. How do I remove them without doing further damage to the heating cable or surrounding tiles? If there was no heating cable under it, i'd grind out the grout and remove the tiles with a sharp chisel. Obviously, doing it that way would wreck the cable entirely.
Any suggestions and advice gratefully recieved, anything that will stop my Mrs whingeing about cold floor tiles!
