- Ultimate Handyman Forum Index DIY Forum/Home improvement Electric Forum UK Lighting
- It is currently Sat Mar 08, 2025 1:46 pm
Extractor Fan
- Has thanked: 2 times
Extractor Fan
Coudl you please supply a disgram of how to wire an extractor fan with timer switch from isolator and seperate pull cord (not on light circuit) thanks
ragdalian
- sparkydude
- Been thanked: 149 times
Post by sparkydude »
do you mean its not to be wired onto the lighting circuit or not to be switched with the other bathroom lights?? answer this and i will be able to give you more help
Nick
Nick
sparkydude
ragdalian
- sparkydude
still doesnt help, do you intend to supply the power from the lighting circuit? or from a ring main?
sparkydude
ragdalian
- sparkydude
right, in this instance you will have to use a junction box, or wire everything back to the isolator switch and do the connections there. You will be better off using a switched fused spur for the isolator just make sure you position it outside the bathroom, high up above the toilet/bathroom door is my usual position.
Wire a twin and earth cable to the switch from the spur and a three core and earth cable from the fan to the spur . and your feed from the lighting circuit to the spur.
Your feed will go into the suply terminals of the spur.
Into the load terminals of the spur connect the neutral to your fan and your permanent live to your fan switch feed. Then in a connector block in the back of the spur box connect your fan switch live and your switched live cables together, all earths to the spurs earth terminal. AT the pull switch you will have a live and a switched live and earth connect up as common and L1
Any more help give a shout
Nick
Nick
sparkydude
ragdalian
- sparkydude
no problems
sparkydude
