Damp floor- flooring options -tiles?
gmt1981
Post by gmt1981 »
Hello everyone.
Now, please bear with me as I may take some time to get my point across being a compete newcomer to DIY.
I have also receive so much contradicting info from so called "tradesmen" it's unbelievable, so I would really appreciate the some advice on the following situation.
Well, basically the house is circa 1870 standard end terrace Victorian. It has had an extension about 50 years ago and that is the problem room as the flooring was laid without any DPM under the existing concrete floor, so there are some rising damp issues (I think).
To add to this, when we bought the house about 6 months ago the existing felt roof (on the extension) had a gaping hole that was letting rain water run down the inside of the walls and then on to the floor. At the time there was a engineered solid wood nailed to batons.
As you will see from the below photo, the room is all but finished with the exception of the floor. The room was actually a bare shell (back to brick) and after consulting various people, we were advised to run a DPM sheet up the walls to about 1m, and then the walls were battened and celotexed accordingly. The DPM also covered the floor so that it acted like a type of bath, but to keep the water from getting to the walls and floors.
Our intention was to lay a floating engineered wood floor (on top of underlay) but after the flooring guy came round, he said there was a lot of moisture under the sheet as it was making the floor sweat. He wasn't keen on laying a floor as it was, and even said that if we laid a liquid DPM with an additional plastic DPM on top, then the water would probably pass through both DPM layers.
The moisture readings taken at the time were 120 and 85, although the 120 reading was due to fresh concrete having recently been laid to level part of the room out.
Clearly I would like to have wooden floors but I have been recommended to lay tiles instead. So out comes the tiling man.....
The tiling man, although recommended by a family friend, hasn't had much experience on damp floors so doesn't know if he can get an adhesive to stick to a liquid DPM. He has got back to me tonight and confirmed that he isn't aware of such a product.
So this leaves me in a bit of a bother. Do you think that if I laid a wood flooring on top of a liquid dpm and further plastic sheet (belt and braces approach), then the floor would be ok? Just how good are these liquid dpm's at keeping the water out. The floor isn't that wet after all, as now that I have removed the plastic dpm covering the floor, the floor has dried out to the touch.
The other alternative is to lay tiles, but do you think a dpm is necessary, and is it possible to get the tile adhesive to adhere to the liquid DPM?
I can't lay another screed as there is only just over an inch to the bottom of the door frame. Oh, and the floor is not moldy, just has 20 odd years of dirt and dust on it.
I really hope someone can help me out on this!
Many thanks in advance
Graham
royaloakcarpentry
Has thanked: 39 times
Been thanked: 621 times
Re: Damp floor- flooring options -tiles?
Post by royaloakcarpentry »
So you have a membrane in the floor now??? Plastic one?? If so, then the floor should dry out to an acceptable level over time. Once the moisture content is correct, then you can lay engineered flooring over an underlay with integral DPM. How long this takes is dependent on climate of the room.
gmt1981
Post by gmt1981 »
royaloakcarpentry wrote:So you have a membrane in the floor now??? Plastic one?? If so, then the floor should dry out to an acceptable level over time. Once the moisture content is correct, then you can lay engineered flooring over an underlay with integral DPM. How long this takes is dependent on climate of the room.
The floor did have the plastic dpm running across the floor and then up the walls, but due to it being ripped whilst decorating, and because of the advice received, it was cut away to leave what you can now see in the photos. The plastic dpm you see actually runs up the walls rather than under the floor.
With winter coming and the fact i need my life back after 6 months of decorating, I don't really want to wait for too much longer for the floor to dry out.
royaloakcarpentry
Hmmmm if you have no DPM under the screed then any liquid membrane you coat the surface with, may divert moisture to other areas, namely your walls.
You can use liquid DPM and then apply another coat but combine fine quartz with it and this will give a key for the tile adhesive and grout to bond to.
Would have been better to have the floor up when you gutted the room, installed a DPM and then screeded.
The floor may well not dry out, due to absence of a DPM.
gmt1981
Post by gmt1981 »
royaloakcarpentry wrote:Hmmmm if you have no DPM under the screed then any liquid membrane you coat the surface with, may divert moisture to other areas, namely your walls.
Thanks for the advice. I am not too bothered about pushing the damp elsewhere, as the walls are protected by a DPM.
I would have dug the floor out and laid another screed, but was advised that wouldn't be necessary.
If only I went on the forum before we did most of the work!
Return to “Tiling Forum”
